If I'm getting a small stream of water when I remove the front plug - does it mean the valve is working okay in this precise moment, or is it not that simple?Onder de witte plaat, zit in het messing aansluitstuk van de pomp tussen bovenkant pomp en kunststof hydroblok
So it worked flawlessly for 6 days in a row (except for two E36 cases that popped up within an hour during a very strong wind, never seen them before or after): normal heating, perfectly hot water (although yesterday night at start the shower felt slightly hotter than at finish, but I did get hot tap water after that), and this morning the heating started, worked for about two hours and then we noticed no flame icon while the radiator icon was on. The radiators themselves were still warm (not hot), as was the pipe going out of the boiler, but the status was already st:8 su:0. The hot water pump felt like working (very subtle vibration on the touch). I tried knocking on the valve and restarting the boiler with no effect. Setting hot water temperature to OFF immediately changed the status and made the outgoing heating pipe hot.Zorg dat eco functie altijd uit staat, eco is geen warmwater. Dat er water uit komt zegt niets over de keerklep, deze kan je alleen op gevoel testen of de weerstand te hoog is.
It happened again last night, water from the hot tap was cold. When I removed the pump plug, I did get a small stream of water out of it, but the stream was cold, while the rubber pipes inside the boiler were very hot. Does prove that the valve is to blame or can it still be the pump?De keerklep of de pomp is de oorzaak, je hebt geen flow sanitair zijdig. Vandaar blijft hij boiler vraag houden en dan heb je geen verwarming. Instelling voor eco staat goed op continue aan.
Thanks, I did remove the central plug when there was no hot water and the pump was rotating. Actually I did it twice in different days, and both times it was rotating. What looked strange was that the water that was coming out of the pipe with the plug removed was cold while all the rubber pipes above were very hot.Controleer nou eens de pomp als je geen warmwater hebt. Op dat moment de messing schroef uit de pomp draaien en een platte schroevendraaier er in steken, als de pomp draait zal hij de schroevendraaier afstoten of gaan ratelen, staat de pomp stil zal je met de schroevendraaier een sleuf in de pomp as vinden, hiermee kan je de pomp aanzwengelen. Als de pomp stil staat is hij defect, als hij draait op het moment dat je geen warmwater hebt, heb je een ander flow probleem dat kan de keerklep zijn.
Happy New Year!Beter aan een installateur over laten
Hello again. By keerklep, do you mean the 3-way valve or something else? I am looking at the parts chart, and the only valve I see above the hot water pump seems to be the 3-way valve 5002. Do you think it is the reason or is it something else?Als de pomp stil staat is hij defect, als hij draait op het moment dat je geen warmwater hebt, heb je een ander flow probleem dat kan de keerklep zijn.
Thanks! It's the one over which the temperature sensor is, isn't it? Would you recommend changing anything else like 5065 too (as there are signs of leakage, but very old ones, I haven't seen it leak there, but probably it makes sense to avoid doing it twice)? And I won't get away with just unscrewing the two 5077, one above and one below, 5007 and 5004 will need to be removed first, correct?Het is 5067
Many thanks for detailed instructions! It's now getting warmer so it's a better time to try this.5065 uiteraard ook vervangen. Cv en sww aftappen maken, rechter schroef van 5001 losdraaien en 5001 naar achter drukken. Zo krijgt de boiler lucht en kan deze helemaal leeglopen via 5069. Als boiler leeg is, pas op water is heet en elektronica in de buurt, dan 5077 losdraaien, pomp verwijderen. Controleer door middel van vinger in 5067 te steken en keerklep omhoog te drukken dat de boiler echt leeg is!! U beugel uit 5007 trekken, dan kan 5067 verwijderd worden. Is lastig klusje als je het nog nooit gedaan hebt.
Thanks for your help and patience! It turned out I'm not sure how to properly drain the boiler (or the draining valve is stuck) but changing 5067 did make it work properly. Let's see what happens when the warming season restarts.5065 uiteraard ook vervangen. Cv en sww aftappen maken, rechter schroef van 5001 losdraaien en 5001 naar achter drukken. Zo krijgt de boiler lucht en kan deze helemaal leeglopen via 5069. Als boiler leeg is, pas op water is heet en elektronica in de buurt, dan 5077 losdraaien, pomp verwijderen. Controleer door middel van vinger in 5067 te steken en keerklep omhoog te drukken dat de boiler echt leeg is!! U beugel uit 5007 trekken, dan kan 5067 verwijderd worden. Is lastig klusje als je het nog nooit gedaan hebt
