Hello,
Sorry that my Dutch is not good and I have to write in English.
I moved to a new apartment and have a problem with the ventilation system. It is said that the ventilation system has a motor in the roof and it is connected to drains in the kitchen extractor and in the bathroom. The problem is the ventilator is always on in the full speed with a lot of noise and I can't adjust the speed or stop it. However, when I turn the related fuse group in the electricity board ventilator shuts down including other kitchen appliances.
There is a classical on-off button switch in the kitchen which supposed to be responsible for it but it doesn't function at all. I'm also sending the picture of wiring of the current switch below.
What I'm think is to replace it with 3 stand (0-1-2 or 1-2-3) or 4 stand (0-1-2-3) ventilator switch so I can control the speed or turn it off. As far as I searched, 3-4 stand switches require 1 brown and 2/3 black wires. However as you can also see in the picture i have 1 brown, 1 black, 1 blue and 1 green/yellow (earth) wire.
My questions are;
1) Is it possible to use ventilator switches with my current wires and how should I connect to a 3 or 4 stand switch. (let's say to 3 stand Schneider ventilator switch in Gamma
Is it possible to use 0-1-2 or 0-1-2-3 stand switches to be able to turn it off; or should it be always on and 1-2-3 switch is the only possibility.
The level of my electricity is also very little so sorry if I sound dumb at all :)
Thanks,
Cem
My questions are;
Thanks,
Cem
