Plastic tray under dishwasher
Why would you?
Almost every dishwasher has a bottom that is waterproof and a float switch that will detect a leakage. In that case the float switch will close the aquastop that is on the end of the water supply hose. In some modern dishwashers there is no more aquastop, but instead a valve in the machine itself. In that case if water is detected by the float switch that valve will close.
So you normally wouln't need such a plastic tray at all!
For extra protection? My dishwasher was leaking and sadly it was discovered by my neighbour as it went straight through her ceiling.
Aquastop I guess can also fail. If you have a leakage in drainage, aquastop will not help. If the door is also, for example, jammed the leak is gonna go through the door, which I believe happened for me.
I think it's worth the extra €15 and was a bit surprised that I can't find it here, in Sweden, its a standard thing.
7
229
Keuken
Bengek18
  • Labee
  • Keuken
  • 8
  • 798
8
798
  • Rosmalentje
  • Keuken
  • 10
  • 6K
10
6K
Keuken
Wilibald
