Xakepa
First: sorry for the English. But its a pickle here.
We moved to NL last year and bought a house, the kettle is old Nefit Ecomline HR30. We did an annual inspection 2 months ago and all was good.
Last night the kettle died, flashing error code 6A (and 7C after restart) - fails to ignite. Cold house, no hot water 2 kids and it's Fri. Nice :)
What I checked so far - water and main voltage are OK, but the fan inside never starts, even during power up! So I pulled both connectors off the fan - there is 230V AC provided to the fan, and 12V DC on the - AFAIK power/data - wire. I took the fan apart - it spins freely and no signs of malfunction. All fuses are OK too.
So I'm lost - I expect the fan to at least try to start at startup, and it never does. So I strongly suspect the fan is malfunctioning. On the other hand I do not understand the controlling circuitry for the fan - I expect it to start spinning once it sees 230V on the mains (without any other input) and when it does not spin I'm not 100% it's the fan that's faulty. The funny thing is - with the fan completely disconnected the kettle goes thru exactly the same sequence of error codes at startup.
So if one can advice how can I make sure I have a faulty fan - and not some other malfunction - that will help a lot, I'll dismantle the fan completely. Otherwise I wait until monday to call the technicians, and they show up when they show up ...
Thank you so much!
Thank you so much!
