AGPO Econpact 127C - doesn't change the temperature
Hello,
I have a AGPO Econpact 127C at home and I'm trying to change the temperature. I didn't manage to find the version of the manual in English so I translated the Dutch version but it is not working.
I changed to mode 1 and 2 respectively (see image 1) and I set the temperatures with new values (see image 2) but when I press C it goes back to the old values (see image 3).
Am I doing something wrong or missing something?
What is the correct way to change the temperatures?
Is there anyone who could help me with that?
Linker display gaat niet knipperen.( Om instellingen te wijzigen) Oplossing inmiddels gevonden:
Chronotherm thermostaat T8851 'vergrendeld' menu optie 0.,0,2 en 9 zodat deze niet is in te stellen.
Stekker uit CV installatie.
Kroon steen Tbv thermostaat losmaken.
CV installatie op 220v zetten.
Naar menu ....nu zijn instelling wel te wijzigen en gaat linker display knipperen.
Kroon steen aansluiten zodat thermostaat ook weer werkt.
