Hi, i think something between the drum is blocking it turning.
You can remove the heater from the back and have a look inside the machine, sometimes a small clothingpart like a sock is between the drum and the outside.
Another possible thing is that the arms of the washingdrum is broken, you can check that by trying to uplift the drum at the front. If so, better go shopping today.
