Hello everyone,
I will try to explain this in english (my dutch is not that great..) however I also don't know all the terms so I hope it will make some sense and someone could give me a hand. Thanks in advance! I am trying to mount some ceiling lights, probably the solution is very obvious but since I've never done this before, I would need a bit of help.
In the first photo the cover plate of the central box is visible fixed onto the ceiling. It has an integrated (not sure if that is the right term) power strip, that I can't remove, into which the L&N (blue & brown) wires are connected. I mention that without removing the plate from the ceiling I can't understand to which of the two slots the L&N wires are connected. I also don't want to remove the cover plate as you see from the picture what happens with the ceiling in case of doing that. In the second photo is the lighting fixture. I also attach the ikea instructions, thought it would be very straight forward since it's ikea but turns out I lack some basic knowledge.
The light fixture has, as well, a power strip onto which it's own L&N wires are connected.
Wondering a few things:
1. How can I connect the lighting fixture to the cables of the electrical system? Do I need other two wires that I use to connect the power strip of the lighting fixture to the one from the coverplate of the central box? Is that safe?
2. How do I know where to connect the L&N wires to the coverplate of the central box, since they have no marking of which is L&N and I can't see how the cables behind are connected, without opening it?
3. The lighting fixture has it's own support plate that is supposed to be fixed onto the ceiling and than the fixture is mounted onto that. Am I supposed to mount this directly into the coverplate of the central box or remove the coverplate and install instead of it? Wondering, since the ground (yellow-green wire) is also present (the lighting fixture doesn't have a connection for that however) and trying to understand how to place it so that it doesn't interfere or get too close to the L&N wires.
Hope someone can give me a hand!
Thanks a lot!
Sorin
Thanks a lot!
Sorin
Bijlagen
682,8 KB Weergaven: 104
